magneto distrub question??? 1960 75 hp jhonson
billbass9
were is the magneto located at? on a 1960 johnson 75 hp seahorse. this maybe a stupid question but isit in the distributor??? <br />the reason i ask is when the distrubtor is off the motor and is spun the plugs spark when there grounded to it.
WillyBWright
Re: magneto distrub question??? 1960 75 hp jhonson
There are two different ignition systems on those. Either battery or magneto. With the magneto, everything is self-contained in the distributor. Sounds like yours is functioning well.
billbass9
well it wasent till i rebuilt it 2 and 4 wouldent fire but i got them sparking hot as 1,3 but dident seem to make any diffrence. it still wont rev up. in neutral or forward,reverse. i checked the timing, points, carb, linkige adjustments, sparkplugs, distrubtor, fuel pump, what else should i check please help thanks for your time
billbass9
its a magneto ignition
