Re: Main seals on CD-15
I thought the early 5.5hp powerhead simply used an oil slinger rather than a seal for the top seal. It should be a little plastic thing that lifts off after the cam on the crank. Usually when I find an outboard with an upper seal problem, the coils and points are covered in oil from it blowing out.<br />If I'm wrong, a local bearing house should be able to fix you up with a replacement if you bring the old one in. Look in the yellow pages under 'bearings'. Normally they supply industry, but they often run a little retail counter too. <br />The lower seal is held in place by the driveshaft like later 5 and 6hp engines. This is made up of a cork seal, an o-ring, some springs and such. I think it's still available from the dealer.<br /><br />Hope this helps!
