Re: Maintenance after you run aground?
Can anyone point me in the right direction to check the water pump? Im assuming I just follow the hose and it will be at the end of it or?
The risk of damaging an impeller with sand makes checking it worthwhile. To get to the water pump you must remove the lower unit. The water pump sits inside, atop the lower unit. Since you've never seen a damaged impeller, unless it is obviouos, you probably won't be able to tell if its damaged or not so my recommendation would to be to purchase the complete rebuild kit (35-40 dollars) and just rebuild it. While your at it, change the lube in the lower unit because it's easy to do when the lower unit is off, (its pretty easy anyway).
I believe the shop manual quotes the job at 1.5 hours so your first time around you can have it done in an afternoon. You should have a basic manual (Seloc $40.00) for reference.
I put mine in forward gear before I pull the L/U and never hit the starter or turn the engine over in anyway while its off. This keeps things aligned just the way they were when they were removed. While working on it I never turn the shafts and when I reinstall it I lube just the splines on the shafts. Lube on the top of the shafts could keep them from seating all the way and could make it difficult to re-install.
When you get ready to install it you can turn the prop shaft in either direction to align the splines if needed. You can only do that in forward gear, hence my method of putting it forward before I remove it.
The water pump parts replacement is pretty straight forward. I take the parts off and lay them out in sequence on a clean bench then install the new parts by matching them to the old and reversing the sequence. I do this everytime no matter how good I think my skills and memory are.
Hope this helps you.
Steve
