Maintenance Merc Outdrive
tak135
I have 2 boats with Merc IO's and after they set in the water all summer, about August the outdrive will not go down, the pump motor will run but I have to put it in F gear to get it down. Do I have to grease the bushing on the HD Cylinders, and if so what kind of grease do I use.
Don S
Re: Maintenance Merc Outdrive
What year and type IO?
Have you checked the oil in the trim pump?
Ayuh,...
The bushings on the ends of the trim rams are plastic,+ Not greaseable...
But,...
There's Plenty of other things that need Grease,+ servicing...
What Year,+ which Model drives,+ motors do you have,..??
At the top of this forum, in the Adults Only sticky, you can download the factory manuals for your boats...
