hooterville
- Joined
- Feb 18, 2007
- 74
ok i have a 1990 48hp Johnson.
I want to keep this engine running as long as i can. I bought the engine when it was 2 yrs old and i was practically new(less than 10 hrs I'd bet). i hardly ever run the thing WOT,maybe 3/4 throttle puts me about 26-27mph.WOT 30mph
I rebuilt the carbs back in the spring that's all the trouble this motor has ever given me.
Aside from new sparky plugs every now and then ,new water pump, changing of lower unit lube, regular uses of sea-foam, what else should i do to my engine?
Is there any recommended overhauling i should do? new rings ?bearings of any type?
I don't mind spending a few $$$ on it since new engines run into thousands of $$$
