I just bought this boat and am doing some routine maintenance on it.
I'm a little confused by the vent screws on this motor. I took out the oil plug - some oil came out - then I unscrewed what appears to be a vent screw that's diagonal to the oil plug (when the motor is fully upright). When I took that out, plenty of oil came out of it. I filled the pan with about 1/3-1/2 a quart.
As you can see in the pic, there's also a larger screw (silver - flathead) further up. But it's so stripped I can't remove it.
Am I OK to change the oil using just the 2 screws I removed?
Sorry about the awful photo, iPhone 3g doesn't like low light. :facepalm:
I highlighted the 3 screws. 2 on bottom I've removed, mystery one up top that is totally stripped and I can't get to budge.
