Maintenance
kevinwburke
I just bought a 2004 Glastron 175MX bowrider with a Volvo 3.0. Having the boat serviced now before taking it out on the water. What yearly maintenance should I have done on the motor and outdrive? Or is there a sticky post for this? Thanks for your help.
kelleyja
Re: Maintenance
need to know more about your engine and drive, but generally......
oil change/tune up
pull the outdrive
check alignment, bellows and anodes
pull the prop and grease your shaft and gimble
scutty
Re: Maintenance
I recently posted my yearly winterization scheme to this thread: http://forums.iboats.com/volvo-pent...a-5-7gsi-four-winns-horizon-210-a-634001.html (I posted to an old message by accident - big forum faux pas - sorry)
Pulling the drive for additional inspection is a good idea but question if it is really necessary to do every year.
This subject comes up a lot, we should have a sticky thread on this.
Also note my method of fogging this engine is NOT and approve method and can cause problems if not done carefully.
Re: Maintenance
Ayuh,.... We Already Do,.... Don'S Adults Only section, at the top of the I/O forums,....
If ya go through the Winterization thread, 'n the Summerization threads,...
You'll know any, 'n All the Maintenance that could, or should be done to an I/O driveline,...
'course, there's Awhole lot more Great info in there too,...
scutty
Re: Maintenance
I've learned a lot from your many posts,Bondo, thanks for pointing this out.
tazrig
Re: Maintenance
Ayuh,.... Cool, glad to hear this peckin' is payin' off,.... ;)
Absolutely! I have a whole folder full of stickies that I draw on and pass down to the newbees.
