major help needed desperately on evinrude motor
hi, first post so please be nice.
I bought a boat 1 year ago, its been in the shop for almost the entire one year. Problem: motor runs and idles on muffs but when in the water it won't stay running, starts hard-have to use the fast idle lever. The mechanic has pulled the carbs three times, the lower unit a couple times, the intermediate unit-to clean it, replaced the main wirring harness, the timming base, one cylinder head and gasket(leaking) and it still does the same thing, wont run in the water. He said the next step is to dismantle the power head and go through it to see if they can find anything wrong. When i bought the boat the po said it was a rebuilt motor. the plate on the mounting bracket say's mod#140943R and ser #j0002840, on top of one side of the engine is a freeze plug thing that has 391227RPH stamped on it. From the mod # i would gues its a 140 hp 1979 evinrude. But, how do i be sure? could be a whole new power head and left the old tag? Anyway, I don't have the money to repower, or have someone else rebuild the motor. The boat goes good once you get it moving forward and running 1000 rpm or so, but slow down less than that and it acts like it wants to stall, rpm flucktuates, goes like hell after 1500rpm and reaches-if i can remenber, about 5500 rpm at wot.
i'm not a mechanic, but can take anything apart, and most of the time back together. Any help would be soooo apreciated. oh, the commpression is good in all cylinders. Any ideas what is wrong, or any wizard mech. near New Port Richey, Fl. ? Thanks
