river_bouy
- Joined
- Sep 28, 2008
- 42
Hi,
I have an '84 suzuki DT50.
During changing the gearcase oil, I have managed to strip the thread of the bottom drain plug (the thread in the hole not on the bolt itself).
Only the first few threads are stripped and then there is a good amount of good thread deeper in. Problem is, the bolt is only real short and does not reach the good thread deeper in. I can get the bolt to hold without the rubber washer seal, but as soon as I add the seal the bolt is not long enough to reach the good thread.
I have tried re-tapping the thread but it is too far gone.
I purchased a longer bolt that screws in find but it is not made of the same metal as the original part (original is aluminium I believe). The bolt I have purchased is just steel that I have sprayed with galvanizing zinc.
My question is, do you think this will be okay? I can hunt around for a stainless steel bolt but would this still cause corrosion issues (two different metals)?
Are there any other options?
Such a small issue but my boat is unusable until I come up with a fix.
Thanks heaps in advance.
