Re: make a 50hp out of a 40hp
Sorry Mitch, I'm afraid you're WAY off base. Rejetting only leans or richens the mixture. Rejetting will only result in a LOSS of power as you will be running either too rich or too lean. If you want a 50Hp, BUY a 50 Hp. If you want a 60Hp, BUY a 60 Hp. Playing with these things like that only gets you a ruined 40Hp. Rejetting is not the answer. Changing the exhaust is not the answer. There are a lot of factors that go into getting the same horsepower from the same block. Fidget with just one and you upset the balance, you'll never get the full effect unless you do all of it, and there's a good possibility of trashing the powerhead if you do just one thing slightly wrong. I'm afraid this far outdated notion of just changing one or two things to change the horsepower dates back to the 1950s. Time marches on. Outboards are WAY more complicated than that now. If your boat is rated for 40Hp, run the 40Hp AS IS. You'll get more satisfactory results playing with props than carbs.
