make your own spark tester
durban
drill & tap into the flat side of the hexagon nut attach a wire & cut the little piece of metal of on the end of the plug fit a crocodile clip on the other end , wear leather gloves when you use it .
boobie
Re: make your own spark tester
For $7.00 at Advanced Auto, I don't think I'll try messing around making one. And it is adjustable.
guys, Durban is in New Zealand. not sure there is an advanced auto around the corner there. for all we know, this may be his only course of action.
Kamcoman
Make sure you are using a non-resistance spark plug. The Advance Auto spark testers do not have a resistor in them.
Keith
mark1961
Ensign
Ive been to Hamilton NZ and can assure you they do have the equivalent type of store/s there.....its no one horse town.....even has its own low volume international airport. :rolleyes:;)
durban
Ive been to Hamilton NZ and can assure you they do have the equivalent type of store/s there. :rolleyes::D
the point is why should i spend money on something if i can make it out of bits & pieces i have in my shed .
mark1961
Ensign
Exactly.....i wasnt suggesting otherwise......just putting things into perspective. ;)
kodibass
Nice job, I made one kinda like it but mine is a double deal so I can see if both cylinders r firing, I work mostly on 2 cylinder outboards and it makes it easy.
tx1961whaler
...and I used to have a store bought spark tester that looked almost exactly like the one Durban made. Looked like a wide gapless plug with a clip welded to the side. Worked fine for the magneto systems, but a high energy system would arc all over the place.
