Making headway on the 68 35hp chrysler model 3551
justin101
Still looking for a good repair book on that model<br />to get the spark plug size and gap,points and so on. <br />The motor sat for about 6 years so far I have replaced the impeller, did a carb kit and replaced the seals in the lower unit. So far it runs great just needs the fine tunning. It smokes a bit but I'm guessing its the carb..?? The impeller was an sob to get off. I had to use a impact screw driver to take out the 3 flathead screws. <br />(tip for someone new like me. After each hit make sure the driver is turning the way you want it. To check the way the driver is moving just place it on wood and strike it. So if you wanted to remove a screw it would turn to the left when you hit it on the wood)<br /><br />I found all the parts here <br /><br /> http://www.theshadconnection.com/marine/cattoc.html <br /><br />It took them about 4 days to get the stuff to my door. If anyone knows of a better place to get parts please post the addy
