I'm getting pretty confused on what I exactly need. I have the '89 Regal in my sig with the 3.7L and the Alpha I (not Gen II) outdrive. I have searched and read, and you indicate it would be easiest with the serial number. Well, I can't really make it out. The best I can make it out is 06569080, but I can hardly see the numbers, only at the right angle, and barely. I don't even know if that number is valid. Once I lower the drive and can get closer in, I might have it better. See pic below.
I can see for sure that the water intake hose is deteriorated, as well as the exhaust bellows. I don't know the condition of the main bellow or the one for the linkage, but I want to replace everything while I am in there. I will inspect the gimbal bearing while I am up in there, and if necessary, then buy the parts/tools to get that done. Hopefully the main bellow was in good enough shape to keep water out.
I was told by my dad that it 'needs the water pump done'. I don't know if it will just need an impeller, or the whole WP kit to include the housing. I would almost feel better ordering the whole thing and being confident that everything is good. I don't want to be stuck for a couple days waiting for a $20 part.
I've read on here to use original Merc parts; if that's still accurate, feel free to point me in the right direction. There are so many places and options out there. Every "Mercury Part Number" I find for what I think I need is different.
I'll answer any questions I can to help you help me get the right things.
Thanks in advance.
See...no good.
Thanks in advance.
See...no good.
