Hey guys I know this topic is beaten to death but this is my first time so I just want to make sure I do it right.
I have a 120 mercruiser in an 86 starcraft. I ran the engine and fogged the carb. then removed the plugs and fogged cylinders as well. Then I found 2 drain plugs on the port side (are there only 2?) I removed them and got a lot of water out. Then I pulled the 2 hoses at the front of the engine and poured antifreeze down them until it poured out of the thermostat housing and exhaust ports.
Outdrive is stored in the down position and gear oil/engine has been changed.
Did I miss anything? I wasn't sure if I should have removed the waterline on the engine coming from the outdrive.
Also I have a 3.0 Mercuiser sitting in my garage that I did this same process to however when fogging it, I could not start the engine. Is that an issue? Or is simply spraying into the carb good enough?
Really don't want a cracked block this spring.
Thanks a lot!
Brad
Thanks a lot!
Brad
