Malfunctioning ESA module?
gregstukey
Is it possible for a bad ESA module on a 92 OMC Cobra 5.0 to cause the engine to die at completely random times--as if you turned the key off? This occurs in and out of the water (running on muffs).
a70eliminator
Re: Malfunctioning ESA module?
Unplug it and see if problem goes away then you'll know, ignition switch would be a more likely culprit.
