Hi All;
I started up my engine this spring to give it a once over. The motor is a 1989 4.3L Mercruiser with an Alpha One Gen One sterndrive.
While timing the engine I notice at idle the battery was being charge at around 12.1V, (this is an option I can select on my timing light). I reved the engine to 3000 RPM to see if the votage would increase, There was no increase.
I'm thinking the volatge regulator is toast. The Alternator is a Mando.
My question is there any rebuild kits available for this alternator. Also could I swap it out for a one wire style. I saw one on the internet for $99.99, it is labled as "POWDER COATED DELCO MARINE ALTERNATOR MERCRUISER 1-Wire".
http://http://www.dbelectrical.com/Items/Item.aspx?SKU=ho-adr0334%20/%2010si-marine%20black%20powder%201-wire&caSKU=ho-adr0334%20/%2010si-marine%20black%20powder%201-wire&caTitle=POWDER%20COATED%20DELCO%20MARINE%20ALTERNATOR%20MERCRUISER%201-Wire
All input and any help is much appreciated.
Thanks
Tom
Thanks
Tom
