Hi all. I just picked up new (GLM) manifolds & risers for my 98 5.0 merc.Alpha 1 raw water cooled.Have a couple of questions about the manifold to riser mating surface, do i need to remove the paint from this area & also (I know this has been kicked around before)the gasket is installed dry, no sealant is that correct? Also the water paths of the original merc equipment and the aftermarket GLM's appear to be the same but the original gaskets had 4 equally sized oval water passage holes, the new gaskets have 2 equally sized oval holes & 2 very small holes. It seems to me like i would be restricting the water path by half with these gaskets??? Thanks in advance.
