manifolds and risers
bpmcl00
Good day.
im sure this question has been asked alot but i was just wondering for my specific case
i have a 1994 mercruiser 4.3lx the boat has only been used about 50 hours last summer and sat for about 5 years prior to that. Anything before that i have no idea
What are some signs that my manifolds and risers will need to be replaced??
Also both of my manifolds were cracked at one point and had been JB welded back together.
manifolds are original and boat has only seen freshwater
Are there signs i should be looking for that they are going out ?
Thanks
Brian
Don S
Re: manifolds and risers
Here is a HUGE sign that you need new manifolds and risers.
bpmcl00
Here is a HUGE sign that you are very close to problems.
haha thanks. i talked to the guy who had the boat beofre me. he said that he didnt drain the manifolds for winter and that was how he cracked them.
besides that. what else should i be looking for as far as signs that they need to be replaced
bomar76
Those cracked manifolds are junk.
If they were to leak into the engine it will destroy it.
Manifolds and risers are a lot cheaper than engines.
bpmcl00
will i be okay just replacing the manifolds or are the risers a must too.
chiefalen
Did you check the block to see if it was jb welded also?
Both manifold cracked?
Bet the risers need to be changed out also.
Complete osco kits on ebasic power.
Stay away from glm.
But as i have posted i would go over that block with a magnifying glass to see if it was welded also.
In the back it could crack also there are casting plugs you can't see there.
I can't believe the manifolds cracked and the block is ok.
Could be.
bpmcl00
Yup incredibly it was only the manifolds that cracked. the boat had only been used for about 3 of the last 8 years. 01 02 partial 03 and all of summer 08 other then that it has just sat between 04-07. also the risers and manifolds are original, and me or the owner of the last year has never had any issues with the epoxy job.
So based on all of this would new manifolds and risers be the way to go.
Or could i get away with new manifolds only.
i only paid 850 for the boat, and was just planning on just riding it out. which it has done so far.
Also fresh water use only
Don S
I would never put old risers on new manifolds.
A FREE boat is the most expensive boat you could possibly own.
bpmcl00
the sad truth. so i guess ill just have to replace them.
based on the looks it seems like a pretty easy job. couple of bolts and clamps.
is this a job for a novice?
chiefalen
When a deal is to good to be true thats the way it usually turns out.
New risers also, and you will be lucky thats all you need.
If it was so negleted how the drive oil look, and all the rubber.
How it ride, does it overheat?
When was the t-stat changed last.
Freshwater i think is what is saving you.
Me i would pull the drive also, for a look around.
Do you have a manual?
bpmcl00
well i took it too a mechanic beofre i bought it. he said:
transom was solid
compression was 150 for all cylinders +/- 7
Drive oil was "great" and didnt even need to be replaced
carb could use a rebuilding but would function okay without it
one stringer was Semi rotten but would hold for a couple more seasons
i told him the price and he told me if i didnt buy it he would.
He looked at the manifolds and said he had seen that happen alot and that jb weld would hold for a little while but ultimately was not a permanent fix.
other then that i have ran the boat a couple of times with no issues at all.
bpmcl00
transom was solid
iv got the online manual. and have been using that studying everything and learning all i can. my next step is to change cap rotor plugs and wires.
and eventually manifolds and risers now :(
Chris1956
Change the gear oil, even if it looks good. The gearcase may be low. Grease the fittings, especially the ginball bearing (grease fitting on transom shield). Check the bellows for cracks. Change gas filter and engine oil and filter. Use straight weight (SAE-30 or SAE-40) oil or Mercruiser 25W-40 oil.
Manifolds and risers are easy to change, if the bolts are not corroded. With your freshwater useage, they should be fine. Use mercruiser gaskets (silver ones), as they are superior to aftermarket green ones. Put them on dry.
180shabah
15 year old boat with rotten stringers and cracked manifolds for $850 - not bad if it came with a trailer.
The "chief" suggested pulling the drive - this is a must. you already know that you have rotten stringers. Your engine alignment is going to shift on the soft wood and this will destroy the coupler requiring the engine to be pulled for replacement. Also, you need to inspect/replace the gimble bearing, bellows(all 3), shift cable and the trim sender and limit switch. And, don't forget the water pump in the lower unit.
Any "new" boat will easily cost $1000 to bring it up to snuff, if you have to pay someone else to do the work figure 2-3k.
bpmcl00
Yes this is something i have been dreading. Pulling the drive.
is this something i can do myself. i have read alot about it. but was just wondering if it was something that i can do myself.
does this fall on the easy scale or hard scale . or in between.
i know i have you guys for help which is awesome.
sundowner205
Just remove the trim ram nuts, the rod that goes through from one side to the other, and the six bolts holding the drive on to the pivot housing. You may have to wiggle it to break it free.
Be sure before you reinstall it to replace the gaskets, o-rings, the impellar, & gimbal bearing.
Inspect the bellows and u-joints as well. Replace if cracked or rusted.
Finally be sure to use an alignment bar when reinstalling the outdrive. Thay can be found on ebay for $30 - 50 dollars.
180shabah
Yes this is something i have been dreading. Pulling the drive....
No need for dread, pulling the drive is easy - as mentioned above just put the drive in forward gear, disconnect the trim rams, remove six nuts and pull. A gen2 alpha weighs 86lbs so you can do it yourself, but a friend is helpfull when you are ready to reinstall.
chiefalen
Paid 300 for my boat and trailer but all i wanted was the trailer .
Paid 400 for the donor boat and trailer.
Yea get the alignment bar, i thought Dixie is using all fiberglass stringers?
Make sure it's in alignment, your gonna need that bar, and when one of your friends pull a merc ,it's free beer time for you when you bring it over.
If i were you i would call or e-mail them and see what they used in that model, year boat.
They are still in business i believe.
bpmcl00
yes the stringers appear to be fiberglass. but i could be mistaken. and only one is rotten towards the aft.
Also my boat was made by Dixie marine INC which is no longer manufactured.
to my knowledge dixie only makes outboard drive boats now under the name Dixie LTD
you say this job is easy so that is some relief on my part. i have been wanting to do this so i can get everything looked at, and i will be able to see any potential problems.
also the boat is due for an impeller im sure so that is something that i will be able to due while i have the whole thing off.
basically if i remove the drive and fix everything that needs to be fixed this will greatly improve the life span of my boat correct???
Thanks everyone for the much appreciated imput :)
Ayuh,....
That would be Correct......
If it Doesn't need a new set of Bellows,+ lower Shift Cable,..??....
I'd be Surprized..... Being all Original,+ all....
