Manifolds and risers
nickmo
Mercruiser 5.0 liter TKS needs dry joint manifolds and risers. This is the 6th season and the engine is running hotter than normal. I've done some research and a search here to get opinions on brands. The Merc OEM stuff is much more expensive ( you get what you pay for ) but I've read that some aftermarket units are actually better. They're heavier which would mean thicker cast iron. It seems that GLM is a brand to stay away from maybe. I know this is a frequently asked question, but I'd like to hear from some of the knowledgeable people here.
Ayuh,..... I had bad luck with GLMs,.... Had to remachine 'em to flatten 'em,....
kbsunlovers
Have had a set of Osco's (not dry-joint) on mine for 4 seasons now. Fresh water, occasional short trips in salt. 0 issues. Have had them off at least three times because I insist on tinkering with things that probably don't need tinkering. Couldn't be happier.
