Re: Manifolds/Risers
Howdy,
Will there be any tell tale signs that my manifolds and risers are ready to be changed out or will they just go on me -and if they go what can happen to the engine.
Not always.
Saltwater manifolds and risers if left long enough will sometimes clog with rust such that one side will start running hotter than the other and/or will clog enough to cause over heating at progressively lower and lower power settings (if the water cannot get out the engine will overheat)
Also, if the risers have not been removed and inspected (probably every 2 or 3 years or so in salt) and new riser gaskets installed, you could get leaks into the exhaust area which would damage the engine fairly quickly.
When you DO remove the risers you inspect them at the sealing surfaces and internal area you CAN see for rust.
If you have a 2000 boat with original exhaust manifolds and risers you should consider removing them, inspecting carefully and plan on replacing them if there's a question.
NEVER wait for symptoms of cooling system problems in a salt water engine!!
"Preventive" maintenance in a salt water engine will help prevent engine destruction due to a riser or exhaust manifold failure.
(is this a "closed-cooled" engine?)
Cheers,
Rick
