Re: Manual/Auto Aerator Switch
I think I now understand the system, below is how to rewire the switch to make it manual and automatic.
The reason for the rotary switch (2 in the drawing below) is to make the timer adjustable. Number 1 switch is non adjustable and works at one cycle speed, the #2 rotary switch can vary the cycle times.
If that is the case, and you would also like to make it work manually as well, all you have to do is rewire the switch as shown in the picture below.
Add a single green wire to one end terminal and splice it to the other green wire for manual. Put the red wire on the other end terminal of the switch, and the purple wire to the center terminal of the switch.
As far as that manual/auto switch goes, it's probably layed out for 6 or 8 terminals on the back, but only 4 used. The manufacturers only make one basic switch, the insides and number of terminals is changed for the type switch.
Here is one I found from Sierra as an example. The layout may change between manufacturers, you will need to determine how yours is layed out.
