manual needed
Barefoot!
i have a 97 40hp force power series by mercury motor (factory install on a tracker boat) and need a repair manual but not sure which manual to get......mercury or force? also, do i order mercury or force parts?
also, can someone point me in the right direction as to what kind of volt tester to get to check electrical components...maybe a link?
here is a pic of said motor cover ;)
Barefoot!
Re: manual needed
ok, was just looking at dva's and was a bit shocked at the price. can one not use a standard needle guage multimeter?
roscoe
Re: manual needed
You need the Force repair manual, factory if you can find one, otherwise, get the Clymer brand Force manual.
Regular multi meter can be used for most things, but a dva is needed for some ignition tests. Start with a regular multi meter.
Barefoot!
Re: manual needed
ignition is fine....i just need to be able to test the stator and power pack for now. is a multimeter ok for that?
where would one find a factory manual...all i can find on the net it the clymer and seloc.
