Hello, I am new to the forum and need a source for a physical copy for a 1963 50hp Mercury outboard. I bought a 1964
13' Boston Whaler with the above mentioned motor on it. The motor runs fine at speed but will not idle in neutral without stalling. Also, just where is the pee hole supposed to be ? The previous owner showed me what he said was the pee hole on the left bottom of the motor when viewed from the stern. No water comes out when the engine is running but the engine does not seem to be overheating. I ran a small drill bit manually up the hole but it made no difference. Other pictures on this forum for this motor show a pee hole/drain hose coming from the top of the motor. Which is correct ?Thank you all in advance for any help you maybe able to give me. I am new to outboards and need all the help I can get !
