manual tilt lock
does any one have instruction on how these work or setting them have two manuals but no info i realize they lock around the pin but dont seem to lock just sitting there is there something else with these
thanks
F_R
Re: manual tilt lock
You don't say what motor we are talking about. However on most all OMCs, the tilt lock holds the motor down so it doesn't suck itself up out of the water in reverse gear. They are meant to be operated in the lock position if there is a choice. They have an overload mechanism that releases it if you hit bottom or a log. If you don't believe it, lock it down and then get behind the boat and grab hold of the lower unit skeg and yank it rearward....hard. It will release with a loud noise sounding like you broke it. But all is well, that is normal. You have to yank a big motor a lot harder than a small one.
Having said all that, if you are running at slow speed through shallow water or stumps, where you know dang well you are going to hit something, go ahead and release the tilt.
F_R
Won't lock, huh? That's interesting. I can think of reasons why you wouldn't be able to unlock it, but not the other way around.
Is the pointy knob on the front, in the center, above the transom, present and free to swing from lock to unlock position? It is linked by a rod to the claws that grab the tilt rod. Swing it one way and it lowers the claws to grab, swing it the other way and it lifts the claws away from the tilt rod. If it were missing or broken, the claws would be in grab position all the time. You must have some kind of problem where it is stuck swung to the unlock position.
will try but forum does not allow very big pictures
trying to upload a diagram for something else but wont take it
Walker
A lot of those older motors only lock down in reverse. They unlock in forward or neutral.
F_R
But this one locks down manually by the lock/release knob. I don't know why this one doesn't lock. Maybe the link rod from the knob is bent or replaced by a jury-rigged affair?
F_R
I'm telling you there is no relationship to the reverse or gearshift. It is locked down or unlocked strictly by flipping that little knob one way or the other. That's it, period.
HighTrim
Jack you can use a site called photobucket to post your pics on here, just follow the instructions.
Walker
That is correct on an electric shift motor.
