Woodbinekeith
- Joined
- Sep 1, 2009
- 86
New-to-me boat so it is in the back yard. I don't have the electrics hooked up yet and wanted to tilt the motor up. It lifted maybe 1" and then seemed to lock rather come up further. The two tilt plungers at this point were about 4-5" up.
I turned the "air" screw counter c. and thought if I let the air pressure off I could lift it up - but no go. When I let it down the 1", the motor went down into the vertical position and the two tilt plungers went right down to the casing.
What to do now to get it up into the tilt? Can I do it manually or do I now have to hook up the battery and use the tilt control? Since the tilt is right down, I guess it would be a good time to check the hydraulic fluid.. ?
