Mariah SX22 with a little smoke
Dutchlarson
My Mariah SX22 puffs a little bit of white/grey smoke every now and then.
Not much, just a little, little bit.
When i start it, and i also noticed when i was cruising at low speed and made small turn. (after a long run at high speed) I have captains call exhausts just above the waterline. Could it be that its just a bit of water going against the hot exhaust?
When i am idling, there is nothing to see and it runs great.
The engine starts and runs great, no mather if hot or cold. No oil consumption, and has about 380 hours on it. Temp, and oil pressure are good also.
Is this normal?
A little now and then I don't see an issue, could be many things but most I wouldn't think of a problem. What motor to do have?
