MariDeck vs Marine standard vinyl
Frankiea87
hey guys currently i have carpet and i hate it.. im looking to replace it with vinyl.. i seen on overtons they have MariDeck vinyl flooring and cabelas has a Marine Standard vinyl.. in both pics they look familiar. i do have marideck samples and i like the way it is. i was wondering if cabelas marine standard vinyl is the same texture. it is cheaper then overtons marideck.. anyone ever install it in their boats? thanks
JimS123
Re: MariDeck vs Marine standard vinyl
I customized my 2009 Starcraft and wanted to match the floor. I got samples from everybody. The Marine Standard Vinyl was the OEM supplier to Starcraft, plus a few other boats I saw at the boat show. It's also almost the same as in my other boat - a 1984 - and it has help up awesomely.
The only difference I can see with Marideck is the color pattern. Overtons will sample you if you want.
Anyway, I highly recommend it.
Frankiea87
yea i got a sample from overtons.. just not cabelas but im assuming its similar.. got a pic of your installation?
JimS123
I added a small foredeck so I could mount a flagpole socket, put a floor in the bow area, and covered the aluminum front bench seat so I could bolt on a swivel seat. The first pic was taken before I mounted the seat.
ajgraz
I put the Cabela's brand grey textured flooring (surely made by Nautolex, it's virtually the same stuff) in my Starcraft 15' tri-hull 7 years ago.
It has held up fairly well, considering I didn't do a great prep job on the deck, I spread the adhesive too thin, I didn't keep the boat covered as much as I should have (SoCal sun did fade it), and I occasionally rinsed the floor with dilute bleach to get rid of cut bait smell and fish blood (also faded it). I know better about all these things now. :p
The downsides are that it doesn't conform to bends/corners very easily, and that it is not very cut-resistant (as attested to by the areas behind my lounge seats where the cut ends of the pole supports cut the flooring, and a few areas where I dropped tools and knives.) Also, if you don't glue it down real good, water will get under it...and it takes a metric crap-ton of adhesive to stick this stuff down properly, particularly so that edges don't peel up. The texture does also retain a lot of dirt.
I'm redoing my boat interior now. If I had a perfectly flat deck (or could wrap it around edges like in the pics in the previous post) and nothing that would gouge or cut it, I would not hesitate to use it again (with proper prep and install, of course). In fact, I am going to use stored leftovers to wrap kickplates and hatch covers, cover the inner gunwales, etc.
I may use it again for flooring, but I'm leaning toward a deck coating (Overton's Tuff-Cote, Durabak, or the like) instead because I think it will take more abuse and be easier to hose down.
ezmobee
I just installed Nautolex in my boat. Based on how poorly my installation went....I'm not likely to use it again. I got air bubbles galore. And it does use a metric ton of adhesive which is expensive.
JimS123
Maybe installation technique has a lot to do with it. Certainly the amount of adhesive is critical. I have some past experience with upholstery work, so maybe I was lucky.
I applied the adhesive with a trowell then skimmed it with the serrated edge. What I put down is not going anywhere, I can assure you. I tested a few pieces before I actualy covered the real pieces and the vinyl was welded to the wood.
The boat I bought in 1971 had that flooring. I kept the boat 13 years and loved it. In 1984 when I ordered my current boat I special ordered it with Nautolex instead of the carpet.
My '84 (with factory floor) still looks like new and has sustained no damage thus far. Interestingly enough, last summer I came across my old '71 sitting on a front lawn with a forsale sign on her. Looking at her after the previous owner abused her for the past 26 years made me want to cry. Nevertheless, the floor still looked good.
When I fitted the '09, in my mind there was no other choice for the floor.
