Re: Marine engine vs. Car engine?
I actually have an engine from a '74 NOVA that the PO put in, the main difference in mine was the camshaft, the Marine has a little more lift & duration. also the mount on the front of the marine block for the RH side of the front mount, isnt there on the auto/truck block so my PO made a peice of alum, If you PM me, I might be able to get you a closer pic.
You'd need to use the electrical components as mentioned from your current engine, DO NOT USE THE HEI DIST !!! - its not safe.
You need to also pay attention to the year of the cylinder head and if it has Hardened Exhaust Valve seats, Pre-HEVS Heads needed LEADED Fuel to keep the Exhaust Valve Seats cool and from sinking into the head.
What's wrong with your current engine ?
