marine grade plywood vs treated
Dennis1958
Hi,
I'm getting ready to deck out my 1996 Lowe Deep V fishing boat. I was going to use treated plywood from my local hardware store but was told that even though it was treated , that it would buckle in a few years. They said always use marine grade plywood. Is this true or will treated work just as well?
ps any web sights on how to deck out a boat ? I see wiring questions in some forums.... Is there a one stop place to get some direction and ideas?
Dennis
JB
Re: marine grade plywood vs treated
Marine grade is a lot stronger than "treated", or exterior grade, Dennis. It is also a lot easier to finish.
Lowe is a pretty good boat. It deserves the best.
steelespike
PT will out live you and while it may not be as strong as
marine grade it should work fine.I have 3/4 inch on my seats and a small front deck spanning over 30 inches.
Also did the transom.All are over 20 years old.Transom unpainted and unsealed. All still solid no rotting cracking or delamination.Just check for compatibility with aluminum.It needs to dry well before painting.
Texasmark
Marine grade is made of more and thinner laminates which insures increased strength (comparable to cabinet grade plywood) for a given thickness. Reason is strength vs weight as weight is always a problem with boats.
Additionally, it is glued together with marine (water resistant) glue. Has nothing to do with the wood's ability to resist water/parasites. Wood is wood.
To protect it you have to apply a protective agent.
Mark
