marine grade
birdy3897
Instead of buying really expensive marine grade plywood couldn't I just by a good sheet of hardwood and put some type of water seal on it? I am just making a deck up front for a bass style seat on an old tri-hull, it don't have to last but maybe 5 years or so. I can get a sheet a good sheet of hardwood for about 38 bucks and was thinking about going with thomson water seal. Would this work??
surlyjoe
Re: marine grade
the only thing hardwood is the exterior veneers,and will not be waterproof glue. at the very least use exterior grade fir, I still recomend the real deal tho.
crab bait
Re: marine grade
birch an red oak ply ( an ALL oak ply is red oak ) rots like a garden tomato..<br /><br />a piece of AB DOUG FIR cost the same 38 to 45 bucks.. <br /><br />no home center carries AB.. but any lumber yard can have it in 3 days..
imported_Curmudgeon
Re: marine grade
One side is "perfect", the other may have very slight defects, like a knot or two. Be careful what the edges look like - that's one of the things that sets marine gade apart (smooth, no voids to wich moisture).
Realgun
Re: marine grade
I cut throught 4 sheets of Exterior plywood and there are very very few voids. I understand about voids but there are not that many. Two coats of epoxy and they are pretty much sealed for life anyway. Be sure to do the edges too.
