Marine hardware question
truckermatt
Hello,
I am re doing some of the interior of my boat and am having trouble finding some hardware,
I have posted some pictures
My best description is a bolt that has sharp edges to grab the wood to prevent the screw head from spinning when you are tightening the nut.
the panel i am re doing, has a screw under the foam and vinyl so in order to attach it back on the boat i need them .
Thanks for your help
boat bolt 001.jpgboat bolt 002.jpgboat bolt 003.jpgboat bolt 004.jpgboat bolt 005.jpg
oops!
Re: Marine hardware question
hi bud.
that is a standard insert.......its a threaded clip that is pushed into the wood. it has 4 teeth on it....
avalable at any big box hardware store.
sorry i forget its proper name
45Auto
It's a tee-nut.
The big box stores have them in plain steel, if you want them to last you can get them in stainless steel from a marine store.
Your originals rusted away because they were plain steel, at least they used stainless screws.
truckermatt
thanks for the reply,
this one has threads in the middle and 4 spike to hold itself in the wood
smokeonthewater
yep... all tee-nuts do...... Also the nut generally used that way to keep the screw from turning... the screw is supposed to be put in through the other panel (whatever you are attaching the padded panel too) and into the tee-nut goes in from the opposite side of the panel... IE inside the panel/cushion before you add foam and vinyl
This is not to say that it can't be done the way yours is but just that it is an improvised method.... If it works for you then go for it.....:cool:
truckermatt
It's a tee-nut.
yes the screws are stainless, but this is all original hardware, so i think 21 years with a steel tee nut isnt to bad.
Actually the wood rotting was the main reason for replacment
Its funny the floor is solid all around, but little places this the side panel and some seats cushions were rotted out, But thankfully they are all easy & cheap repairs for the DIYer
truckermatt
I think i need to install the tee nut that way because that panel attached onto the fiberglass rail with a flat washer and locknut. If its worked for wellcraft, it'll work for me.
View attachment 115448View attachment 115449View attachment 115450
Fireman431
Finding SS T-nuts locally may be tough. The box stores usually don't carry them, just steel. If you have a decent marine store, you might find them there. If not, order online. Standard size is 1/4" x 20. The larger panels use 5/16".
truckermatt
thanks guys for all the help,
I went to West Marine and got some stainless tee nuts,
NYBo
Lowes carries them. Look in the specialty hardware drawers in the fastener aisle.
