Re: marine lube in truck??
I park on concreet and it has,nt been leaking,I just checked it and it was,nt up to the fill hole so i toped it off,I talked to an ase ford mechanic and he said not to worry about it,the marine lube was better than the auto lube anyway..
Check the brake drum backer plates for dampness. The axle seals will weep, and when the oil hit's the drums it gets slung out, so you will not see a prominent leak. The other problem with an axle seal leak is your brake shoes will get contaminated with gear oil.
It just so happens I'm an ASE Master tech/L1, and I don't agree with the Ford mechanic. Ford specifies 75W-140 synthetic for that diff, and has been since the 10th generation F-150 came into existence in '97. I own a '97 F-150, V6, with an 8.8 open diff, and that is the only fluid I will use. While it's expensive, and I can't tell you the difference between a diff that calls for standard 80W-90 and this one, it's piece of mind that I'm not going to smoke the bearings or knife edge the gears using the wrong stuff.
Ultimately it's your truck, do with it as you wish.
