Re: Marine Lumber?
Kaptain,<br /><br />As I was cautioned, DO NOT USE PRESSURE TREATED WOOD if you plan to encapsulate the wood in glass or attach glass to it.<br /><br />Pressure treated wood (new stuff) is very wet when you purchase it, it has significantly more weight than reqular (or Marine plywood). If the wood does not dry out, I am told it will rot from the inside out. Also you will have a very hard time getting resin to stick to presure treated, it will delaminate.<br /><br />There is a lot of info on this subject in these forums, just do a search on "marine plywood".<br /><br />Peace.<br /><br />Ed.
