Re: Marine ply question
I have the ability to get marine grade ply for 50 dollars a sheet. it is 2x as expensive as cdx. is it worth it? In the end I would think it would be cheaper due to not needing as much resin and glass to waterproof, right? I have also heard that when using it, it isnt necesarry to coat the bottom of the deck in resin, is this true?
1. Is it worth it.. Depends, if its for a transom then yes, if it's for a deck maybe.
2. Less expensive because of less resin.. Standard Marine grade plywood is just fir ply that has minor to no voids making it stronger. It is not made with waterproof glue, it's just like exterior in that it is made with water resistant glue.
3. If the plan is to use it on a deck and you were thinking of using 3/4 because of the potential for large occupants then with marine ply you could still use 1/2" and you won't have to adjust for that extra 1/4" when you start putting things back together. This alone could be the best arugument for using marine ply.
If you're looking to get out of all that glass work you won't by using marine ply. You need to step up even further and go to SuperPly from Roseburg Lumber Mills. It is supposed to be made from clear sheets of veneer and is assembled with resin glue that is 100% waterproof. 3/4" will run you 130 - 150 a sheet and you'll need to special order it.
Even then you still should coat it with at lease a Spar rated 1 part polyurethane finish.
Discalimer: This aint gospel, everybody seems to have different results and opinions on the subject. This is my two cents and based on my own experiences.
