Marine Power 5.7 voretec Alarm buzzer oil and water temp secondary sender locations
Billnet
I have a marine power 5.7 vortec carbureted engine that I want to install an oil and water temp alarm buzzer kit. It comes with two senders for oil pressure and water temp. I have the two for my gauges installed. I do not know where to find the plugs for adding the second set of senders. Hoping someone can help me out.
the 5.7 has a oil ports up at the back of the block by the dizzy and one on the boss for the oil filter
for water temp, there should be an additional port in the intake manifold water headder
Ayuh,.... Welcome Aboard,.... You could also "T" off either, or any of 'em,.....
