In response to several posts I've read here I thought I would offer the following information for marine wiring. <br />These part numbers are from NAPA, Belden Wire Products.<br />For the battery cables
- <br />
- #726613 Heavy Duty Crimping Tool<br />
- #726605 Extra Heavy Duty Cable Cutters<br />
- #726607 Extra Heavy Duty Bench Mount Cable Cutters<br />
- #726604 Hammer Driven Cable Crimper<br />
- #726606 Battery Cable Stripper<br />
- #726602 Heavy Duty Cable Cutter Pliers<br />
- #7276** Heavy Wall Heat Shrink Tubing - Adhesive sealant lined<br />
- #72812* Solder Pellets (should you choose to use)<br />
- #7285** "Fusion" Solder Connectors ("Fusion" strength at least 2X crimp)<br />
- <br />
- #738301-738310 18ga Primary Wire<br />
- #7384** 16ga Primary Wire<br />
- #7385** 14ga Primary Wire<br />
- #7386** 12ga Primary Wire<br />
- #7387** 10ga Primary Wire<br />
- #7388** 8ga Primary Wire<br />
- <br />
- ****01 = Brown<br />
- ****02 = Red<br />
- ****03 = Orange<br />
- ****04 = Yellow<br />
- ****05 = Green<br />
- ****06 = Blue<br />
- ****07 = Purple<br />
- ****08 = Gray<br />
- ****09 = White<br />
- ****10 = Black<br />
- ****11 = Tan<br />
- ****12 = Pink<br />
- <br />
- #784664 = 14-18ga 5" 3pc Clear tubing<br />
- #727612 = 8-12ga 9.5" 5pc Black tubing<br />
