Mariner 200 idling problems in deep water
Daz
Hi
I have a 1986 Mariner 200 and am having problems with it idling when the leg is fully down in deep water. The revs drop and it stalls. The strange thing is that if you raise the leg on the trim so it is about 25 degrees up the revs pick up enough to idle smoothly.
Can anyone suggest what might be causing this?
Thanks
Daz
Barnacle_Bill
Re: Mariner 200 idling problems in deep water
You may have some trash in your low speed jets in the carbs. Or pin holes in the fuel pump diaphram. It runs better when you raise it because there is less back pressure.
Daz
Thanks very much for the pointers. I'll have a look into the areas you highlighted :)
Thanks
