Mariner 200HP Starting problem
nikoale
Hi guys, I've got a 1994 200hp mariner that works perfectly fine apart from the following problem. Once the engine has been running for a while and its turned it off, it does't start again unless I use the throttle accelerator during ignition. Any hints as to what the problem might be? Any help would be much appreciated, thanks
