I recently changed a Stator and two switch boxes(just before winter storage). Now when I ran up motor after bringing out of storage I found I have too much oil smoke causing a oil slick on water when I go above about 2500-3000 rpm. This only happened before when engine was still warming up. Now at idle everything seems to be fine. All the power pack voltages and stator voltages and resistance check good. Pretty sure this motor was bad when I bought boat as the neutral start switch is wired around at the remote. Until I get up to the 2500/3000 rpm range the motor seems to have a little exhaust smoke, but no oil slick. Looks pretty much normal for a two stroke in this area. Any idea's ??? This is an EFI/Oil injection model serial number B122102, 2.4 Liter V6.
