mariner 25 impeller?
chrbartlett
i have a mariner 25 late 80's and i need to change the impeller where is it ? and how do i change it?
JB
Re: mariner 25 impeller?
Howdy, MM.<br /><br />Let's try the Mariner troubles forum.
Vlad D Impeller
Hello there MM, Welcome to the iboats forum, you'll gain access to the impeller by disconnecting the lower unit. <br />I suggest you acquire a service manual for your motor, read it about 3 to 4 times prior to starting this procedure.<br />Good luck and keep us informed of your progress, there are lots of good folks here to guide you along should you get stuck :)
north40
MM<br />Go to BassBoatCentral.com and click on Sherm's Tips. He has a good explanation of changing water pump. The advice on getting a manual was good advice as you will need it quite often.<br />Good luck,<br />Bob
chrbartlett
cheerz for the help how can i tell exactly what model and age it is because i cant find the serial number. I need this info to order a manual cheerz
