maineiac5586
- Joined
- Feb 14, 2009
- 770
Got a 1996 mariner 30 elo (2 cylinder single carb with oil injection). Looking to remove oil system and mix manually. Anyone know the procedure to do this? Can I leave the oil pump attached to the block? Just disconnect and plug oil pump lines? Will there be a warning system that needs to be over ridden so it doesn't put the motor into a fail safe mode? Thanks for any help with this
