Re: Mariner 45hp leaking carbs
sounds like the floats are too low not allowing the fuel to shutoff
pull the carbs check your levels,
with the floats exposed you can blow air thru the fuel inlet, use a hose with your mouth....you will hear the air when the floats are open, lift the floats to close the needle and continue to blow, you should not hear air or be able to blow when the needle is closed
hope this test helps you get it resolved before assembling again
