Mariner 4hp Wash Screw?
reeflodge
Hi
I have a 1988 4hp mariner which has been a very reliable little engine.
near the bottom of the leg are 2 screws, 1 is for oil and the otherone say "WASH" does anyone know what this is for?
Thanks
Paul
carholme
Re: Mariner 4hp Wash Screw?
Paul;
Should be for the fitment of a flushing attachment which is used to flush the inside of the cooling system. Once the attachment is inserted, you can connect a garden hose to it, much the same as using the muffs to run the engine on land.
Gerry
reeflodge
Thanks Gerry
Does the motor need to be running when using this method?
Paul
carholme
Paul;
No, don't run it when using the flushing attachment. If you want to run it, use the muffs.
Gerry
