Mariner 75 Oil Injected Dead In The Water
TERRYCLARK
Pontoon died going down lake, was running fine and just died, no missing or anything. NO spark. Unhooked fuel line and cranked engine and fuel was pumping. What to check next ?
BatDaddy1887
The very first thing to check is the 20amp fuse at the engine. Also, the kill switch lanyard. If good then start the whole electric test series starting with stator, coils, power pack(s), rectifier, etc.
You may get some insight from this website.
Silver Eagle
check your kill switch,try this ,take the clip off of the kill switch then press the button at the switch all the way in then crank the engine over .if it starts put a dime between the clip and the switch. it works..'
TERRYCLARK
The kill switch is a toggle switch. How do you check it ? If you replace the Stator or Trigger does if have to be retimed ? Thanx !
MH Hawker
Do you have spark, thats the first thing to check, its unlikely its fuel or the kill switch being as it was running and died, more than likely its a ignition component i would suspect the stator or the switch box.
steelespike
You'll get a lot better help in the Mercury/Mariner forum.This is pontoons.
TERRYCLARK
No Spark..
TD_Maker
No spark at all? My gut feeling is ignition switch grounding out, or kill switch went bad....especially if it just died while running.
lncoop
I know this is Pontoons..............Just trying to get a little help ! Been to Mariner / Mercury forum. Thanx !
PM faztbullet and CharlieB and ask them to take a loot at your thread in Merc/Mariner. Good luck with the issue. I know that's frustrating.
