I am running a 1989 Mariner 75hp 3cyl with no problems once the motor is warm. The problem is the cold starting routine. It takes at least 5+ tries to get it and sometimes it still wont turn over. New lines, vent open, fresh fuel, new primer bulb, full charge battery, new plugs, no leaks in fuel lines, enricher valver working. Engine seems to flood perhaps with the usual starting technique. When i tilt the motor out and the gas runs of the carbs, I can sometimes start it by turning the key, but not pushing the key in to open the enricher valve. Once tickover, all is good. Restart well after warm and the leftover fuel is burned off. Is this a stuck float, needle, ?fuel pump prob (doubtful), enricher valver, etc. Overall still a great engine but starting is a challenge.
