mariner 75hp 3cylinder 2 stroke con rod torque settings requied asap
Bennettrj
I have my 1988 3 cylinder 75hp engine in bits just put crank and pistons back in but am now stuck as I don't know torque settings for con rods and head too block bolt settings
many thanks
Bennettrj
Re: mariner 75hp 3cylinder 2 stroke con rod torque settings requied asap
20.3nm 0n 650 and 800 mercury is as close as I can get on information so far
carholme
From page 174:
Always renew rod cap bolts
when reassembling power head.
Threads are cut into both the connecting
rod and rod cap. Tb properly align
cap and rod during reassembly, proceed
as follows: Place rod cap (9) on bearing
half (8) and hold tightly against connecting
rod while threading in bolt. Finger
tighten rod bolts then check rod and cap
alignment. Cap and rod must be perfectly
aligned. After all rod caps and bolts
are installed and aligned, tighten bolts
to 15 in.-lbs. (1.7 N-m) and recheck alignment.
Then tighten bolts to 30 ft.-lbs.
(40.7 N'm) and recheck alignment. If
rods and caps are perfectly aligned,
tighten rod bolts an additional 90 degrees
to complete procedure.
Here is a link to the condensed version of the Clymer manual. Download it soonest to your computer as the link is short lived:
MARINER - MARINER 75 AND 90 HP 3-CYLINDER (AFTER 1986).: Small Engine Repair Reference Center Home
See other torques on first page.
Gerry
