Mariner 9.9 just dies
fishfinger
I have a 9,9 hp mariner,single carb ,the out board starts sounds like it is running on one cylinder,runs for a bit say a minute and then dies ,stine dead as if you cut the fuel supply off,it take a lot to start it again,definatley running on one cylinder.
I removed to carb to find that inside the motor there are 3 thin metal plates on either side, looking into the throat, the right hand side plate’s have a fine layer of rust just where they open and close, tried to clean it a bit but has made no difference to the engine, any idea’s what these plates do? My outboard is about 7 years old and has been in storage for 3 years ,I have cleaned the carb and the plugs both have spark.
The outboard has a total of about 15 hours of duty in it’s life.
Any help here would be great
South Africa
tashasdaddy
Re: Mariner 9.9 just dies
if it has sat a lot i would consider changing the impeller also.
fishfinger
at the risk of sounding like and idiot....i am not to technicaly sound if you could describe to me what the intake is and where to to look it would help a bit
tashasdaddy
you best get a manual. or a mech. manuals at maxrules.com
deejaycee_2000
Hey fishfinger, welcome to iBoats ..... I see you are from South Africa, PM me and I'll explain in Afrikaans ..... as I get from your typing you are afrikaans ....
