Mariner 9 HP compression issues
inlandlake
I have had this small outboard 2 stroke motor ( on a 12 ft aluminum boat) for two years after buy from a friend at church that bought it new in 1992. He used it earlier on but not much before he sold it to me . After I bought it two years ago it started very easily and continues to start very easily. However last year it would run for about 30-45 seconds and bog down and it would easily start up again but then do the same thing 30 seconds later . I brought it in and they cleaned the carbs and at the end of the season I took it back out and the same thing happened so I put it away for the season. This year I changed the gas , plugs, ignition coils. The same thing happens bogs down easily but starts up easily and when running runs fine for about 30-45 seconds and gets the boat moving very well and up to speed. I took the motor in this week and they said it was probably the fuel pump and maybe the bulb and tube had debris ( very old tube) and was feeding fragments into the gas causing a supply issue. They called yesterday and stated the compression was 45 in both cylinders. I found this odd because it runs so well for 45 seconds. Thoughts? I didn't think a motor would run well with compression as low as 45. is the compression check they are doing reliable? The mechanic said I he would try to rebuild the fuel pump and clean the carb but didn't guarantee anything. Thanks for your thoughts about the compression.
Austin
Are you mixing gas and oil at 50:1 in the tank ?----Did you install a new water pump impeller ?---A 9.9 HP ??-----Serial number?
inlandlake
yes 50:1 in the tank then well mixed, 9.9 hp serial number OC268922. I did not install a new water pump impeller but there is a steady get of water flowing out which if figured indicated the cooling system was intact.
QBhoy
Floats sticking. Clean the carbs well. She’ll be fine. It will be a 9.9hp you have. Made by merc. Can also be converted to 15hp fairly easily. Great engines. Check the fuel primer operation she has. Not technically a choke, rather a prime system they have. Make sure it’s not sticking and working properly.
Bring it home and do the compression test yourself.-----If it is indeed 45 PSI it will need some serious work.----I believe you can remove bypass covers to look at pistons and rings.
QBhoy
I think if it actually was that low…a quick look down the plug holes with a torch would tell a story of things. Really doubt it actually is though.
We can not see / touch these motors.----Posters need to do the inspection and report what they find.----There is no magic to this.
