Cadwelder
- Joined
- Aug 30, 2010
- 1,780
I had an exhaust / water leak on my 115 Mariner (0B153107) in line 6, I replaced the inner and outter gaskets and cleaned the carbon from the inner plate, and it hasn't leaked anymore. I never mentioned this in other post since I thought it wasn't an issue. However after reading some other forums (not iboats) it was mentioned that a warped exhaust plate can cause high end running problems. I used geniune Mercury gaskets and torqued all the bolts to factory specs.
I would think if it was warped it would be leaking, correct? Also, would this cause high end running problems anyway? Thanks for you help, I sure you're tired of hearing my posts, just trying to get this thing running correctly.
