imported_stump jumper
- Joined
- Jul 19, 2006
- 71
I have had some other posts and I am getting close to fixing all the problems from the sinking. I pulled the carbs and cleaned them, replaced a couple of wires that were suspect, replaced the fuel line and went to a portable tank to eliminate fuel problems. I replaced the spark plugs. I fired the boat up and it ran perfect, idled great and was firing on all 6.
I put the cover on the motor, trimmed it up and drove to the boatramp (1 block away) the motor turns over but does not start. I suspect the key switch and I am wondering if there are any wires coming from the engine harness to the switch that would prevent the plugs from getting fire. Is there something that I could be missing? Neighbor tells me to pull the flywheel, I just feel the answer is simpler than that. Please help so I can use my boat this weekend.
